JMPUser9
Equations to open in new data table
I need to calculate two separate equations to open in two columns in a new data table. Is there a way to do so?
Re: Equations to open in new data table
Is this what you are talking about.  This script creates 2 new columns, each with a different formula:
dt =
// Open Data Table: Big Class.jmp
// → Data Table( "Big Class" )
Open( "$SAMPLE_DATA/Big Class.jmp" );
dt << New Column( "one", formula( :height + :weight ) );
dt << New Column( "two", formula( :height / :weight ) );
Yes, but we'll need more specifics to give a useful answer. What steps do you need to take, and are you looking for a scripting answer, or one that can be accomplished in the GUI?
dt =
JMPUser9
Jim, thanks for the feedback. I'm looking to run a script where
select where name is Katie and Tim, then height = 59 + 60
In a new table
Names     Height Sum
Katie/Tim       119
And then any combinations I specifically call out.
Here is a simple script that provides one solution
dt =
theNames = {"KATIE", "TIM"};
theRows = dt << get rows where( dt:name == theNames[1] | dt:name == theNames[2] );
If( N Items( theRows ) == 2,
	dt2 = New Table( "Results" );
	dt2 << add rows( 1 );
	New Column( "Names", character, set each value( theNames[1] || "/" || theNames[2] ) );
	New Column( "Height Sum", set each value( Sum( dt:height[theRows] ) ) );
	Try( dt2 << delete columns( "Column 1" ) );
