EduardDerks
Equations in JMP pro Notebooks
Is it possible to get formatted equations in JMP Notebooks, like in Jupyter?
My version is 19.0.5 JMP-pro.
Eduard P.P.A. Derks, PhD
Senior Data Scientist
Avient Protective Materials
Re: Equations in JMP pro Notebooks
This might be a good idea to submit to the Wish List. The developers are likely looking for what people want to see in Notebooks.
Closest I can come up with is appending a formula using the Expr as Picture () command:
EduardDerks
I'll submit my wishes for future versions. Would be great if the JMP Notebook's could behave in a similar way as Jupyter Notebooks, especially when it comes to reporting equations.
Thanks for the suggestion!.
jules
Hi @EduardDerks.,
@Jed_Campbell 's suggestion to add this to the wish list is a great idea, please do that.
Also, there is a slight modification to @Jed_Campbell's suggestion that might get you slightly closer, which is to omit Current Window(), and start with the bare put-to operator ( i.e., << ), which tells Notebook to emit the resulting display box to the block output directly, rather than at the bottom of the window.
<< Append (
	Expr As Picture( Expr( (-b + Sqrt( b ^ 2 - 4 * a * c )) / (2 * a) ) )
I hope this helps!
jules
