Dennisbur
Embed Data
Hello
When I need to save any graph, I receive a pop-up to choose the option.
I see with one of my colleagues that to save the graph without the pop-up, I should choose any setting in preference.
I would like it if you could address me to the right place where I can cancel it?
Re: Embed Data
You can change the setting from JMP's preferences and use search function (this setting is under Reports section).
To access Preferences you can pres Ctrl+K or access them from File menu
Re: Embed Data
Byron_JMP
Re: Embed Data
in my humble opinion, there is nearly never a reason to save a graph as you have described. in nearly every case it causes unnecessary problems. Either the graph is easy to disassociate from the data or the data is duplicated. Both will generally end badly.
Please consider clicking on the red triangle menu at the very top left and Save the Script to the Data Table.
This keeps the graph script with the data and, obviously does not duplicate the data.
