waltp
Dynamically adding a Table Box to an Outline Box
I would like to add Table Boxes to an Outline box, but do this dynamically as the number and content of the Table Box contents change.  I tried the following script as a example but Table Boxes don't even appear plus there is an error message about the hb reference in the For loop that I don't understand.  Any sugestions?
Thanks,
Walt Paczkowski
tbLst = { Index( 1, 5 ), Index( 6, 10) };
dtM = dt << Subset( Output Table( "x" ), Columns( :sex, :height ) );
for( i = 1, i <= 2, i++,
	dtM << Clear Select;
	dtM << Select Rows( Eval( tbLst[ i ] ) );
	hb << Append( ( dtM << Get As Report ) );
New Window( "test", Outline Box( "X", hb = H List Box( ) ) );
ian_jmp
Level X
Re: Dynamically adding a Table Box to an Outline Box
I think you are close. Is that what you want?
hb = H List Box( );
New Window( "test", Outline Box( "X", hb ) );
ian_jmp
Level X
hb = H List Box( );
waltp
That's exactly it!! Thanks for the help.
Walt
