rugolf
Droite de référence particulière sur un histogramme
Bonjour,
Comment ajouter une ligne de référence (celle de la moyenne) sur l'histogramme de la plateforme distribution lorsque l'on a un sélecteur de colonnes, je souhaite avoir cette ligne pour chacune des  10  variables, évidemment sans avoir à la rajouter à la main ?
Par avance merci.
Jean-Luc
Re: Droite de référence particulière sur un histogramme
You have few options:
  • Set Target of specification limit column property as the mean and enable those in plots. You will need to calculate these beforehand and set them to column properties but summary + manage spec limits should be able to do this
  • JSL: use Column Switch Handler which updates the reference lines as column changes
  • JSL: Create graphic script which is able to update the reference line
  • Use different platform such as Graph Builder in which you can easily add the line as separate element
Below are some examples for the JSL options (there are plenty of different ways of doing these):
Example for the graphic script option:
dist = dt << Distribution(
	Continuous Distribution(
		Column(:height),
		Always use column properties(1),
		Process Capability(0)
	Column Switcher(:height, {:height, :weight})
Report(dist)[FrameBox(1)] << Add Graphics Script(Function({this},
	m = ((this << Top Parent)[OutlineBox("Summary Statistics"), Number Col Box(1)] << get)[1];
	Pen Color("Purple");
	Pen Size(5);
	H Line(m);
Example for the column switch handler:
		Column(:height),
cw = dist << Column Switcher(:height, {:height, :weight});
post = Function({previousColumn, currentColumn, switcher},
	prevm = Col Mean(previousColumn);
	m = Col Mean(currentColumn);
	axisbox = Report(dist)[axis box(1)];
	Try(axisbox << Remove Ref Line(prevm));
	axisbox << Add Ref Line(m, "Dashed", blue, "Mean", 2);
	wait(0);
handler = cw << Make Column Switch Handler(Empty(), post);
