BHarris
Drive table variable with slider?
Is there any way to drive a table variable with a slider?
E.g. suppose I have this:
New Table( "TableVariableSliderExample",
	Add Rows( 100 ),
	New Table Variable( "scaleFactor", 1.5 ),
	New Column( "x",
		Numeric,
		"Continuous",
		Set Values(
			[1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20,
			21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38,
			39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56,
			57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74,
			75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92,
			93, 94, 95, 96, 97, 98, 99, 100]
	New Column( "Sin",
		Numeric,
		"Continuous",
		Formula( Sin( (:scaleFactor * :x * 6.28) / 100 ) ),
... is there any way to create a slider that will modify :scaleFactor and cause the data and any associated plots to live-update?
Re: Drive table variable with slider?
You can have slider in separate window (the slider window creation could be stored to table script for example)
dt = New Table("TableVariableSliderExample",
	Add Rows(100),
	New Table Variable("scaleFactor", 1.5),
	New Column("x",
		Numeric,
		"Continuous",
		Set Values(
			[1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23,
			24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44,
			45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65,
			66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86,
			87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100]
	New Column("Sin", Numeric, "Continuous", Formula(Sin((:scaleFactor * :x * 6.28) / 100)), )
sliderValue = dt << Get Table Variable("scaleFactor");
New Window("Example",
	Panel Box("Slider Box",
		sb = Slider Box(0, 10, sliderValue,
			dt << Set Table Variable("scaleFactor", sliderValue)
or in some cases you might want to build UI which contains the slider AND datatable.
	Add Rows(100),
	New Column("x",
		Numeric,
		"Continuous",
		Set Values(
BHarris
This is awesome, I didn't realize JMP was capable of this.  Thanks!
Just a random follow-on question -- is it possible to draw that slider bar inside of the Graph Builder window?  Or does it have to live in its own window?
Easiest way is to utilize New Window() and add both graph builder and the sliderbox inside that.
