lala
Level IX
Download speed comparison results :python asyncio async download VS JMP MultiHTTPRequest concurrent download
I actually compare the different ways to GET and POST.
python's asyncio asynchronous download is much faster.
  • But the JSL code is very concise.
Re: Download speed comparison results :python asyncio async download VS JMP MultiHTTPRequest concurrent download
Most likely there can be differences and it might be possible that JMP's multiple file import could be optimized as it is fairly new
  1. Which Python and JSL script/code did you use to test?
  2. Did you test on small files? Large files? Mixed file sizes?
  3. Did you test on different file amounts? 1 file? 2 file? 200 files? 10000 files?
  4. How big are the differences?
lala
Level IX
  • The main thing is to download 5000 small JSON data in about 10 seconds.
