Distribution graph with process capability not working in script
I want to use this generated script on numerous columns:
Distribution(
	Stack( 1 ),
	Continuous Distribution(
		Column( :"VDD_ILIMIT"n ),
		Horizontal Layout( 1 ),
		Vertical( 0 ),
		Outlier Box Plot( 0 ),
		Process Capability( LSL( . ), Target( . ), USL( 0.5 ), Show as Graph Reference Lines )
	SendToReport( Dispatch( {"VDD_ILIMIT"}, "1", ScaleBox, {Add Ref Line( 0.5, "Solid", "Blue", "USL", 1 )} ) )
When using this script, all works well, and I get a distribution graph with process capability plot at the same window.
When I try to run it on a number of columns, I get only the distribution graphs for each column, without the process capability plot and data.
// Open the data table
colnames = dt << get column names( numeric, string );
For( i = 1, i <= N Items( colnames ), i++,
	If( Contains( Column( colnames[i] ) << Get Name, "ILIMIT" ),
        // Create a distribution graph for the column
		meanValue = Col Mean( colnames[i] );
		stdDevValue = Col Std Dev( colnames[i] );
		ppkValue = 2;
		uslValue = meanValue + ppkValue * 3 * stdDevValue;
		Distribution(
			Stack( 1 ),
				Column( colnames[i] ),
				Vertical( 0 ),
				Process Capability( LSL( . ), Target( . ), USL( uslValue ), Show as Graph Reference Lines )
			SendToReport( Dispatch( {colnames[i]}, "1", ScaleBox, {Add Ref Line( uslValue, "Solid", "Blue", "USL", 1 )} ) )
What am I doing wrong, and why is it behaving in this way?
Re: Distribution graph with process capability not working in script
Below is a modification to your code that should work for you
i = 2;
	//If( Contains( Column( colnames[i] ) << Get Name, "eight" ),
	If( Contains( colnames[i], "ILIMIT" ),
		//meanValue = Col Mean( colnames[i] );
		meanValue = Col Mean( Column( dt, colnames[i] ) );
		//stdDevValue = Col Std Dev( colnames[i] );
		stdDevValue = Col Std Dev( Column( dt, colnames[i] ) );
		ppkValue = 2; // ???
		uslValue = .5; // this value is used below, but was not assigned
		Eval(
			Eval Expr(  // JMP does not evaluate items in a list as parsing
				        // therefore it has to be preprocessed
				Distribution(
					Stack( 1 ),
						Vertical( 0 ),
						Process Capability( LSL( . ), Target( . ), USL( Expr( uslValue ) ), Show as Graph Reference Lines )
						Dispatch( {Expr( colnames[i] )}, "1", ScaleBox, {Add Ref Line( Expr( uslValue ), "Solid", "Blue", "USL", 1 )} )
i = 2;
		Eval(
				Distribution(
					Stack( 1 ),
						Vertical( 0 ),
JMP isn't able to add the reference lines correctly (and you don't seem to have value for upperlimit?). Below is an example which can give you some ideas
colnames = dt << get column names(numeric, continuous, string);
dists = {};
For Each({colname}, colnames,
	meanValue = Col Mean(Column(dt, colname));
	stdDevValue = Col Std Dev(Column(dt, colname));
	ppkValue = 2;
	uslValue = 3*stddevValue + meanValue;
	dist = Eval(EvalExpr(dt << Distribution(
		Stack(1),
			Column(Eval(colname)),
			Horizontal Layout(1),
			Vertical(0),
			Outlier Box Plot(0),
			Process Capability(
				LSL(.),
				Target(.),
				USL(Expr(uslValue)),
			Dispatch(
				{colnames[i]},
				"1",
				ScaleBox,
				{Add Ref Line(Expr(uslValue), "Solid", "Blue", "USL", 1)}
	Insert Into(dists, dist);
