Ranae
Difference between std error in "Parameter Estimates" and "Least Squares Means Table"?
I am running mixed effects models and have noticed that the standard error for an effect in the "Parameter Estimates" table is different from the standard error reported in the Least Squares Means table for the same effect. How are they calculated differently? Thanks!
0 REPLIES 0
