Deleting table variables
I'm trying to delete table properties in a loop but nothing happens. There's no error message in the log window, so I'm not sure why i can't delete table variables in a loop.
If I use a literal string I'm able to delete the variable, but I would like to delete a list of variables by pattern matching.
dt = New Table("test");
dt << New Table Variable("a", 1);
dt << New Table Variable("b", 1);
dt << New Table Variable("c", 1);
names = dt << Get Table Variable Names;
for(i = N Items(names), i > 0, i--,
    variable = names;
    // Fails
    dt << Delete Table Variable(variable);
// Ok
dt << Delete Table Variable("a")
ms
Super User (Alumni) ms
Re: Deleting table variables
Your example works here, JMP 10.0.2 for Mac. But it may not be working in JMP 9. Are you using a version <10?
Try this in JMP 9:
dt = New Table( "test" );
dt << New Table Variable( "a", 1 );
dt << New Table Variable( "b", 1 );
dt << New Table Variable( "c", 1 );
For( i = N Items( names ), i > 0, i--,
  variable = names[i];
  Eval( Parse( Eval Insert( "dt << Delete Table Variable(^nameexpr(variable)^)" ) ) )
ms
Try this in JMP 9:
I'm using JMP 9. Your solutions works. Thanks
