pauldeen
Delete a text box and a button from a lineup box
I'm trying to delete both the button itself and the associated text box before it. So when I cilck button nr 3 I want text nr 3 to also be deleted. Any ideas?
nr=5;
new window("Button test",
	Lineuplist=Lineup Box( N Col( 2 ),
For(i=1,i<=nr,i++,
	Lineuplist << append(textbox("Text nr "||char(i)));
		buttonbox("Button nr "||char(i),
			<< Set Function(
				Function({this},
					this << delete;
thomasz
Re: Delete a text box and a button from a lineup box
Here is a piece of code that works:
nr=5;
For(i=1,i<=nr,i++,
			<< Set Function(
				Function({this},
					ps=this<<sib;
					par=this<<parent;
					buttonName=this<<get button name;
					buttonNo=regex(buttonName,".*?([0-9]*)$","\1");
					locator=eval insert("//TextBox[text()='Text nr ^buttonNo^']");
					textBox=par<<xpath(locator);
					textBox<<delete;
					this<<delete;
uday_guntupalli
Level VIII
@pauldeen
nr=5;
	Lineuplist=Lineup Box( N Col( 2 ))
For(i=1,i<=nr,i++,
			<< Set Function(
				Function({this},
					this << delete;
	Lineuplist[Text Box(i)] << delete ; // this is the piece of code which will do what you are after . Insert it where you delete the button
Best
Uday
thomasz
nr=5;
For(i=1,i<=nr,i++,
			<< Set Function(
				Function({this},
					ps=this<<sib;
					par=this<<parent;
					textBox<<delete;
					this<<delete;
pauldeen
