skyzvoir0001
Delete Column
I have 190+ columns and I wanted to delete columns stored in the list
Remain_columns = { column names I want to remain}.
How do I do it using for loop?
Re: Delete Column
You do not have to loop through the names.  That is, assuming you want all of the columns named in that list to be deleted.  Below is a simple example
namesCol = dt << get column names( string, continuous );
dt << delete columns( namesCol );
