RonB
Degradation stability test script not working freeze in JMP 17
Can perform the function from the degradation menu but when saving the script to the data table (or script window) and running it - the entire jmp 17 freezes over and needs to be killed.
no such problem in jmp 16.
attached the data table.
Re: Degradation stability test script not working freeze in JMP 17
Are you using JMP 17.1? I can confirm that the script saved to the data table you provided causes JMP to freeze. The script JMP created for me in 17.1 has extra syntax that wasn't in your data table (and doesn't result in freezing behavior). Code below:
/*JMP STATISTICAL DISCOVERY LLC (“JMP”) PERMITS THE USE OF THIS COMPUTER SOFTWARE CODE (“CODE”) ON AN AS-IS BASIS AND AUTHORIZES YOU TO USE THE CODE SUBJECT TO THE TERMS LISTED HEREIN.  BY USING THE CODE, YOU AGREE TO THESE TERMS.  YOUR USE OF THE CODE IS AT YOUR OWN RISK.  JMP MAKES NO REPRESENTATION OR WARRANTY, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO, WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, NONINFRIGEMENT, AND TITLE, WITH RESPECT TO THE CODE.
You may use the Code solely as part of a software product you currently have licensed from JMP, JMP’s parent company SAS Institute Inc. (“SAS”), or one of JMP’s or SAS’s subsidiaries or authorized agents (the “Software”), and not for any other purpose.  The Code is designed to add functionality to the Software but has not necessarily been tested.  Accordingly, JMP makes no representation or warranty that the Code will operate error-free.  JMP is under no obligation to maintain, support, or continue to distribute the Code.
Neither JMP nor its licensors shall be liable to you or any third-party for any general, special, direct, indirect, consequential, incidental, or other damages whatsoever arising out of or related to your use or inability to use the Code, even if JMP has been advised of the possibility of such damages.  Except as otherwise provided above, the Code is governed by the same agreement that governs the Software.  If you do not have an existing agreement with JMP or SAS governing the Software, you may not use the Code.
JMP and all other JMP Statistical Discovery LLC product or service names are registered trademarks or trademarks of JMP Statistical Discovery LLC in the USA and other countries.  ® indicates USA registration.  Other brand and product names are registered trademarks or trademarks of their respective companies.
Degradation(
	Y( :data ),
	Time( :MONTHS ),
	Label( :BATCH ),
	Upper Spec Limit( 105 ),
	Lower Spec Limit( 95 ),
	Application( Repeated Measures Degradation ),
	Connect Data Markers( 1 ),
	Show Fitted Lines( 1 ),
	Show Spec Limits( 1 ),
	Show Median Curves( 0 ),
	Show Legend( 1 ),
	No Tab List( 0 ),
	Use Pooled MSE for Nonpoolable Model( 0 ),
	Set Censoring Time( . ),
	Show Residual Plot( 1 ),
	Show Inverse Prediction Plot( 1 ),
	Inverse Prediction Interval( No Interval ),
	Inverse Prediction Alpha( 0.05 ),
	Path Specifications(
		Simple Linear(
			Add Custom X Scale(
				{{"Linear", Function( {x}, x ), Function( {x}, x )}}
			Add Custom Y Scale(
			Slope( Different ),
			Intercept( Different ),
			Select X Scale( "Linear" ),
			Select Y Scale( "Linear" )
		Nonlinear Path
	Simple Linear Path( 1 ),
	Mean Path( 1 )
peng_liu
Thanks for bringing this up. This is a known issue in JMP17 and 17.1. It has been patched up in 17.2. Please upgrade when 17.2 becomes available to you.
