jfsilves
Date-Time Formats
I have date-time data in a column of form:
2020-04-30T17:29:48.967-04:00
This data was loaded from a database.  JMP recognizes it only as a string of characters.
How can I convert this into a JMP datetime format?
P.S. I do not care about the timezone (-04:00).
Re: Date-Time Formats
Here is a little script that should convert the column to a JMP date time value
names default to here(1);
dt=current data table();
for each row(
	:date = substr(:date, 1, length(:date)-length(word(-1,:date,"-"))-1);
dt:date << data type(numeric)<<modeling type(continuous);
dt:date << format("yyyy-mm-ddThh:mm:ss");
Just replace the values of :Date to whatever your column name is
for each row(
