Created:
Jul 19, 2022 07:00 AM
| Last Modified: Jun 10, 2023 4:51 PM(1857 views)
Is the anyway to reassign which figures are date and month - 07/05/2022 10:24:21. The column is formatted D/M/Y h:m:s but the date is actually 05th of July.
Messed up 1 data sheet in Excel and concatenating to ones that are correct - please help!
If you have already "messed up" as in the data is wrong, you could maybe try method used hereDate Conversion issue . First change the column to character column -> back to numeric -> change to correct format/use format pattern to fix the data.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '523293' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '523293') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '523293') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
