Level XIII
Database access
when I generate a Database Query via the GUI in Jmp, how can I use advanced SQL functionality?
  • SQL formulas (rand (),txt = Substring(), myValue = a+b )
  • Explode
  • Lateral View
Re: Database access
Most likely JMP's SQL GUI doesn't support all possible SQL commands and functions which are available depending on which SQL is being used but you could convert the query to Custom SQL and add those yourself
or something is maybe found from computed columns
Re: Database access
Level XIII
Re: Database access
red triangle -> hidden wonderland.
concerning
  • Explode
  • Lateral View
... maybe a developer will find this post and consider implementing it in a future release ...
Level XIII
Re: Database access
easier to find: wish list ;)
advanced SQL options
Re: Database access
Thanks for the solution.
