BSwid
Data Filter - Selecting all when there is no alternative value to where does not equal statement (=!)
Looking for some help to understand the behavior or a better way to script this.
Writing a script to catch exceptions in the data. When version is GP but active is not X.
dt = Current Data Table();
df = dt << Data Filter(
	Location( {138, 181} ),
	Add Filter(
		columns( :Active, :Version ),
		Where( :Active != "X" ),
		Where( :Version == "GP" )
Then the rest of the script subsets that data and creates a tabulate from that subset.
The problem I am encountering is when all rows have Active == X.  The filter is selecting all rows.  I suppose that's because it's not finding an alternative to X which is blank (not missing).  What's the best way to handle this?
Result of the above code:
Re: Data Filter - Selecting all when there is no alternative value to where does not equal statement (=!)
OK, it actually makes your scripting easier. No pesky human interaction involved!
The data table message << Select Where( Boolean expression ) will do it all for you. The Boolean expression can be simple (e.g. :Age == 12) or complex (e.g., :Age == 12 & :Sex == "F"). Any function that returns a result that can be interpreted as a Boolean (i.e., 0 is false, not 0 is true) will work. This requirement means that you can use query functions such as Contains( source column, "target" ) for literal targets or Regex( source column, regex ) for patterns.
After you select the rows you want, then send the << Subset() message to extract the data.
6 REPLIES 6
You could first check to see if the condition can be met:
target rows = Current Data Table() << Get Rows Where( :Active != "X" );
If( N Row( target Rows ),
Just checking: why are you using a data filter object? Does the user have to interact for the sake of the script?
BSwid
No need for the user to interface.  Just a novice stealing code after each step done manually and then constructing the code from those steps.  I assume there's a better way to do select the subset and create the subset table?
BSwid
This is very helpful. Thank you.
I ended up doing something like the following.
Scripting question, Is there a better way do to it?  As in did I need the CLE_TL intermediate?  Or can it just be dt << select where << subset  on one line?  Is there a benefit to creating that CLE_TL object?
names default to here(1);
dt = current data table();
shipPlant = "CLE";
shipMode = "truckloads";
subsetTable = "CLE_truckloads";
//filter
CLE_TL = dt << select where(:TransportPlanningPt == shipPlant & :MODE == shipMode);
//subset
CLE_TL  << Subset(
	Output Table( subsetTable ),
	Selected Rows( 1 ),
	Selected columns only( 0 )
BSwid
Quick note.  I used your suggestion to help with one analysis. On to the next.  That's why the coding doesn't match the screen shot.
