DOE Custom Design
Hi
I have a question regarding I-optimal design generation in JMP.
When generating I-optimal designs, I sometimes obtain designs with relatively high confounding between terms. In some cases, the largest confounding is between two-factor interactions, while in others it involves main effects or quadratic terms.
I would like to know whether there is a way to impose constraints on the level of confounding during the design generation process, rather than relying on trial and error after the design has been created. For example, I would like to specify requirements such as:
Maximum confounding between main effects: ≤ 0.10
Maximum confounding between two-factor interactions: ≤ 0.15
Is there a way in JMP to define such criteria before generating the design, while still maintaining the overall design quality and optimality?
N.B. I tried the Prior parameter variance option but when I assign square terms below the others but it become confounded above 0.6
Victor_G
Re: DOE Custom Design
Hi @PoynomialIguana,
Welcome in the Community !
Do you have a specific use case to share to see what the problem may be related to ? Usually, if you have a sufficiently high number of experiments in your DoE with no specific constraints (disallowed combinations, linear constraints, mixture constraints, ...), you should get relatively low aliasing between your effects and higher order effects.
If you're worried about the aliasing, I would perhaps recommend trying to change your optimality criterion to :
You can also improve design generation by augmenting Number of Starts and increasing Design Search Time. It may sometimes be helpful for complex cases (for example high dimensionality/number of factors with constraints).
You can also generate several designs with various optimality criteria, number of runs, replicates, centre points, etc... easily with Design Explorer and compare the best promising designs.
Hope these few suggestions may help you,
Victor GUILLER
