sweetycha
DATA WIDE TO LONG FORMAT
Hi all
I have data in wide format  i.e col  with  three variables: predicted, upper and lower and respective rounding options like round up of predicted, upper and lower, round down of predicted, upper and lower etc. which I want to  reorganize it in long format i.e  some constant rows like date and all of the value has to be reformatted into longer.
I have attached the " have" and "want" data.
Any help is highly appreciated.
Re: DATA WIDE TO LONG FORMAT
Go to
    Tables==>Stack
and stack all of your predicted columns, and you will have what you want stack.PNGstack.PNG
You need to take the time to read the document called Discovering JMP and Using JMP....both are available at
     Help==>JMP Documentation Library
