EH1
EH1
Custom background color to show quadrants in Graph Builder
How do I customize the background color in Graph Builder to show 4 different quadrants (i.e. Quadrant 1 is a different color than Quadrant 2 which is a different color that Quadrant 3, etc.)?
Thank you!!
Re: Custom background color to show quadrants in Graph Builder
JMP allows one to add graphic primitives to any of the graphical outputs within the system.  So to produce the below graph
You just right click on the native graph and select "Customize".  It brings up a window that allows you to add a script to the graph.
You can then take the modified graph, and do a Save Graph which will look like:
dt = open("$SAMPLE_DATA/big class.jmp");
Graph Builder(
	Size( 528, 456 ),
	Variables( X( :weight ), Y( :height ) ),
	Elements( Points( X, Y, Legend( 5 ) ) ),
		Dispatch(
			"weight",
			ScaleBox,
			{Add Ref Line( 110, "Solid", "Black", "", 1 )}
		Dispatch(
			"height",
			ScaleBox,
			{Add Ref Line( 60, "Solid", "Black", "", 1 )}
		Dispatch(
			"Graph Builder",
			FrameBox,
			{Add Graphics Script(
				2,
				Description( "" ),
				Transparency( 0.5 );
				Fill Color( {1, 1, .5} );
				left = Current Report()[axisbox( 1 )] << getmin;
				top = Current Report()[axisbox( 2 )] << getmax;
				right = Current Report()[axisbox( 1 )] << getmax;
				bottom = Current Report()[axisbox( 2 )] << getmin;
				Rect( left, top, 110, 60, fill = 1 );
				Fill Color( "red" );
				Rect( 110, top, right, 60, fill = 1 );
				Fill Color( "green" );
				Rect( left, 60, 110, bottom, fill = 1 );
				Fill Color( "orange" );
				Rect( 110, 60, right, bottom, fill = 1 );
			), Grid Line Order( 1 ), Reference Line Order( 3 ),
			DispatchSeg(
				TopSeg( 1 ),
				{Set Script(
However, there is a simpler form that most programmers find more convenient
gb = dt << Graph Builder(
	Size( 528, 456 ),
report(gb)[FrameBox(1)] << add graphics script(
Graph Builder(
	Size( 528, 456 ),
		Dispatch(
			"weight",
			ScaleBox,
		Dispatch(
			"height",
			ScaleBox,
		Dispatch(
			"Graph Builder",
			FrameBox,
				2,
				Description( "" ),
			DispatchSeg(
				TopSeg( 1 ),
				{Set Script(
	Size( 528, 456 ),
EH1
EH1
Thank you so much for your help!!!  I greatly appreciate it!!!
Bertelsen92
Interesting to be able to mark certain parts of the graph with a color.
Is there any chance you could do this without scripting??
I have only done it partly using reference lines with overlapping (which I would like to avoid) - see the attached screenshot.
Have a nice day.
Kristian Bertelsen
Technology Specialist
There are a couple of ways that you can add items to your graphs.
Annotations
The Tool Bar above the JMP Display Window contains some icons that permit the adding of annotation items to graphs
Text, Arrows and Line, Polygons and Circles can be added.  The are added on top of the graphics display.
You can also right click on the graph and choose "Customize" which allows for the addition of items using graphic primitives.  While these use JSL, they are very simple to use and they allow you to add colored areas, text, lines, etc and they can be positioned at any level of the display.
Bertelsen92
Thanks a lot for your reply. These are excellent tips and both make good sense.
Kristian Bertelsen
