hogi
Level XIII
Custom Function - add comment
Some of the examples in the Scripting Index have lots of details and useful comments:
When a user submits a function via Add custom Function(), such comments are automatically removed:
What do I have to do to see the comments?
Add Custom Functions(
	New Custom Function(
		"test",
		"f",
		Function( {}, Print( "hello world" )
		<<Description( "test function" ),
		<<Example(
			Expr(
			x=3;
		// here I want to add a comment which will be displayed in the scripting index
				f()
Re: Custom Function - add comment
Usually JSL Quote() can help with these type of situations. Additional benefit is that you don't have to use strings when building your functions
myAdd = New Custom Function(
	"custom",
	"Add",
	Function({x, y = 1},
		x + y - 1
myAdd << Example(JSL Quote(// add first to second
	a = Add(1, 2);
	Show(a); // a = 3;
Add Custom Functions(myAdd);
	"custom",
	"Add",
		x + y - 1
	a = Add(1, 2);
	Show(a); // a = 3;
