abhi_dp
Creating a new character column by sorting multiple columns
american_indian
asian
black
declined_race
multiracial
pacific_islander
unavilable_race
white
0
0
0
0
0
0
0
1
0
1
0
0
0
0
0
0
0
0
0
0
0
0
0
1
0
0
1
0
0
0
0
0
0
0
0
0
0
0
0
1
0
0
0
0
0
0
0
1
1
0
0
0
0
0
0
0
0
0
0
0
0
0
0
1
Is there a simple way (without a script) to create a new column (race) that can sort each of the individual columns information? I would like the new column to be something like this:
american_indian
asian
black
declined_race
multiracial
pacific_islander
unavilable_race
white
Race
0
0
0
0
0
0
0
1
white
0
1
0
0
0
0
0
0
asian
0
0
0
0
0
0
0
1
white
0
0
1
0
0
0
0
0
black
0
0
0
0
0
0
0
1
white
0
0
0
0
0
0
0
1
white
1
0
0
0
0
0
0
0
american_indian
0
0
0
0
0
0
0
1
white
jerry_cooper
Staff (Retired)
Re: Creating a new character column by sorting multiple columns
Selecting the columns you want to combine and then choosing Cols->Utilities->Combine Columns... from the menu will give you a dialog box in which you can specify the new column name and then check the "Selected Columns are Indicator Columns" box. Clicking OK will create the column you are looking for. Note that if a row could have more than one "1" you should also check the "Multiple Response" box, in which case, the entry in the new column will be the column names concatenated by the character chosen for delimiter ("," is the default).
Hope this helps.
-Jerry
Georg
Can be done by a formula using the if statement, there you are most flexible and can use conditions on other columns or even combinations of columns.
Georg
jerry_cooper
Staff (Retired)
Hope this helps.
-Jerry
abhi_dp
Thank you! That was easy :)
