NewToThis
Creating a column and Filling all rows by a date and time
I Want to create a column named, say, :CHANGE and then fill all rows by a date in the format 01/15/2026 7:02:26 PM. How do I do that.
For some reason JSL does not recognize this format
Re: Creating a column and Filling all rows by a date and time
In my opinion only reliable way to format your dates to specific format in JMP (while keeping them as numeric) is to use Format Pattern
dt = New Table("Untitled",
	Add Rows(7),
	Compress File When Saved(1)
dt << New Column("CHANGE", Numeric, Continuous, Format("Format Pattern", "<MM>/<DD>/<YYYY> <hh>:<mm>:<ss><AMPM>", 21, 0), Set Each Value(
	15Jan202619:02:27
JSL Syntax Reference > JSL Functions, Operators, and Messages > Date and Time Functions
Using JMP > Set JMP Column Properties > About the Column Info Window > Numeric Formats
	Add Rows(7),
	15Jan202619:02:27
NewToThis
Can't thank you enough for this. Thanks
