RA899
Corrupted Power Point Slides.
Hi all,
I'm running into a problem where when I export the data to power point, the power point indicates the slides are corrupted and then the PPT slides closes after that. I can't even get a preview of the data.
jschroedl
Re: Corrupted Power Point Slides.
Can you add a bit more context such as JMP version and maybe which platforms are in the report you're producing? Does it fail for other reports. For example, if you open Big Class.jmp from the samples, run the distribution, then File > Export to PowerPoint?
John
