caroljackson
Copy Paste of Charts is cutting off end of chart
When copy and pasting a chart into Word or OneNote, the chart gets cut off on the right side.  Using JMP PRO 12.2. Any advice?  I am new to JMP PRO but old to JMP :)
statman
Re: Copy Paste of Charts is cutting off end of chart
Unfortunately I am not running 12 currently to try and replicate your issue, but you have multiple options:
1. First Journal the window (Ctrl-J) with the graphs you want (the window must be at the front).  Then, if you are on Windows, you can Save As the Journal as a Word document.  If on a Mac, you can export it as an RTF and then open it in Word.
2. Try Exporting the graph as an image (File>Export, select image and the format you want).
I sometimes experience this issue when moving my laptop to-and-from a docking station. I have found that a restart resolves the issue.
