Claus_Jensen
Copy Cell value to column name and to spec limits
Hi All
I have i challenge i need to coly the values of the cell in rownumber 8 to the column name for a lot of collums is there an easy way to script this.
My next issue is that i have spec limits both low and high including Sepc units in 3 diffe rows is there a way to script this to the Spec limits om the column
ian_jmp
Level X
Re: Copy Cell value to column name and to spec limits
For the first part, you could try something like this:
NamesDefaultToHere(1);
Wait(3);
for(c=1, c<=NCol(dt), c++, Column(dt, c) << setName(Char(Column(dt, c)[8])));
For the second part, take a look at 'Analyze > Quality and Process > Manage Spec Limits' and the associated help.
ian_jmp
Level X
Wait(3);
