aandw
Control Graph Label Value Decimal Output in JSL Script
I would like to control the decimal output for graph labels within JSL script.
I need to set the number of decimal places displayed explicitly, as opposed to graph builder default.
For Example:  Increase decimal from 3 to 5.
I have been unable to locate this control within Garph Builder Axis Settings or JMP Preferences.
I assume the control command occurs within or just after the  Label( "Value" ) command.
Using DiamondData sample dataset.
// Sample dataset DiamondsData
// Review Directory
dt = Open("C:\Desktop\DiamondsData.jmp");
// Create Average of Carat by Cut
new column("cut_carat_agv",
  numeric,
  continuous,
  formula( Col Mean( :Carat Size, :Cut))
//Graph hBar of Average Carat Size by Cut with Bar Label "Value"
Graph Builder(
  Show Control Panel( 0 ),
  Variables( X( :cut_carat_agv ), Y( :Cut ) ),
  Elements(
  Bar(
  X,
  Y,
  Legend( 2 ),
  Bar Style( "Side by side" ),
  Summary Statistic( "Mean" ),
  // Assume Decimal control for Label occurs here
  Label( "Value" )
  Dispatch(
  "graph title",
  TextEditBox,
  {Set Text( "Average Carat Size by Cut" )}
  Dispatch( {}, "X title", TextEditBox, {Set Text( "Average Carat Size" )} )
pmroz
Re: Control Graph Label Value Decimal Output in JSL Script
If you double-click on the X axis, the format is shown at the top.  In this example I changed Dec from 1 to 3.  When you click on the graph builder little red triangle and copy the script this is what you get:
Graph Builder(
     Elements(
           Bar(
                X,
                Y,
                Legend( 2 ),
                Label( "Value" )
           Dispatch( {}, "cut_carat_agv", ScaleBox, {Format( "Fixed Dec", 10, 3 )} ),   // Here's the format
           Dispatch(
                "graph title",
                TextEditBox,
aandw
// The command appears to control the x-axis label.
// I am attempting to control the value label applied to the graph bar
// Apologies if I have misinterpreted.
Graph Builder(
  Elements(
  Bar(
  X,
  Y,
  Legend( 2 ),
  // Assume Decimal control for Graph Bar Label occurs here
  // within Lable command
  Label( "Value" )
// or subsequent
  // this Dispatch command appears to control x-axis label decimal
  //Dispatch( {}, "cut_carat_agv", ScaleBox, {Format( "Fixed Dec", 10, 3 )} ),
  Dispatch(
  "graph title",
  TextEditBox,
pmroz
Hmmmm not sure how to set the format of bar labels.  Looked at the graph builder tree structure but there didn't seem to be a place to control that.
gb = graph builder(.....)
gb << show tree structure;
