tdiehl
Concatenate values in a column
Seems like this should be simple, but I cannot find a clear example.  I would like to concatinate the values in columns of a specific name("ROW" and "COL") and create a new column with the result in it.  Example below.
ROW    COL     CELL
   5          1         5_1
   3          2         3_2
  12         -1       12_-1
best shot at code so far:
column("ROW") << Data type(Character);
column("COL") << Data type(Character);
//a = {column("ROW"), column("COL")};
ConExpr = concat items({column("ROW"), column("COL")} , "_");
//Add "CELL" column = concat col(ROW) "_" col(COL)
dt << new column("CELL",Character, "Nominal", Format("Best", 12), formula(eval(Expr(ConExpr))));
my results:
CELL
   _
   _
Any help in understanding why my code evaluates to that and the correct implementation would be greatly appreciated.
Re: Concatenate values in a column
Here is all you need to do:
dt << new column("CELL", character,
     formula(:ROW || "_" || :COL));
