vince_faller
Complex Numbers in JSL
Is there any hint that JMP may add complex number support into JSL in the future?
I've seen the namespace("Complex") Stuff but wondered if there was going to be a more substantial addition.
Vince Faller - Predictum
ian_jmp
Level X
Re: Complex Numbers in JSL
I just uploaded an (old) add-in I wrote to mimic what Microsoft Excel does:
https://community.jmp.com/t5/Documents/Complex-Numbers/ta-p/22616
If you install it, look for Add-Ins > Complex Numbers > and look at the help and sample data.
ian_jmp
Level X
Hi Ian,
  I am a JMP11 user, I have license to JMP12 through my company but I haven't installed it yet. I would like to get complex number capability into JSL, however I am unable to open the add-in link you attached. How can I get this add-in? is this the only way to have complex number capability in JMP? Thanks!
Tom
ian_jmp
Level X
I'm sorry Tom. When you say 'unable to open the add-in link', I'm not quite sure where the issue lies. Can you download the .jmpaddin file? If 'yes', what happens when you double click on it?
