Mickyboy
Level V
Comparison of VCA between JMP and R
l am looking at a study that was performed in R, l have managed to replicate the results of the VCA in R using the following syntax, VisDil1 <- lmer(l2t ~ (1|Op/Day/MDCK) , Dil1), for the following results
Random effects:
Groups                 Name       Variance      Std.Dev.
MDCK:(Day:Op) (Intercept) 0.02309       0.15195
Day:Op               (Intercept) 0.00861       0.09279
Op                      (Intercept) 0.00000       0.00000
when i run what i believe is the same model in JMP i get
Random Effect   Var Ratio    Var Component Pct of Total
MDCK[Day,Op]    0.1904762      0.031746     16.000
Day[Op]                0                        0                  0.000
Op                        0                        0                  0.000
Residual                                   0.1666667        84.000
Total                                         0.1984127       100.000
l used the following script
Fit Model(
	Y( :l2t ),
	Effects,
	Random Effects( :MDCK[:Day, :Op], :Day[:Op], :Op ),
	NoBounds( 0 ),
	Estimate Only Variance Components( 1 ),
	Method( "REML" ),
	Run Model
i looked at this across 8 dilutions, and it is the same result in each dilution, R has a variance component for Day:Op, whilst jmp is combining this effect into it into the effect MDCK[Day,Op], so l feel i am not specifying the model in JMP the same as in R to get the same result.
Does anyone have any advice???
Thanks
Mickyboy
Level V
Re: Comparison of VCA between JMP and R
when i posted it has cut the residual component off, from R, here it is again
Random effects:
Residual 0.16670 0.40829
Please clarify the structure of the design and the randomization.
Op is at the top of the hierarchy.
The 4 Days are different for both Op.
The two MDCK are different for each day and Op.
Isn't titer a potentially important fixed effect?
Mickyboy
Level V
Hi Mark,
Thanks for your reply, please find attached a copy of the nested design, l agree that the syntax dosent reflect the design of the experiment, l think a more appropriate model would be
RBC
Day[RBC]
Op[RBC,Day]
However, thats another story, what l am trying to understand is why when l run what l believe is the same model in both R and JMP, I get a variance component for Day in R, but JMP seems to combine this component into the MDCK variable.
The variable l2t is the log2 of titer, the independent variable.
Thanks
