student
Comparing strings not working for variables
Hi, I am using JMP 15 on Mac. The following code works:
dt = current data table();
Current Data Table() << Row Selection(
Select where( (:Stat == "Max"), Current Selection( Extend ))
But this doesn't:
var = "Max"
Select where( (:Stat == var), Current Selection( Extend ))
Can someone explains what is wrong with the second one?
student
Re: Comparing strings not working for variables
Ok I solved it. This is what was missing:
(:Stat == (myStat))
So, the variable needs to be inside two parentheses!
Try moving var = "Max" outside the << Row Selection(). And add missing ;
student
No change (thanks for your reply though).
student
(:Stat == (myStat))
Seems like there is something a bit weird going on (tested with JMP16.0 on Windows 10). Take careful look on the brackets when using Row Selection
Example from scripting index (works fine):
dt << Row Selection(Select where(:age < 15));
Wait(2);
	Select where(:age == 15),
	current selection("extend")
Adding variable before second row selection and using it (returns Scriptable[]):
Wait(2);
ageVar = 15;
	Select where(:age == ageVar),
Moving the bracket from end of Select Where to after current selection (seems to work fine, but this syntax seems wrong for Row Selection based on Scripting Index):
Wait(2);
ageVar = 15;
	Select where(:age == ageVar,
	current selection("extend"))
When using Select Where platform the script generated seems to be:
Data Table("Big Class") << Row Selection(
	Select where(:age == 15, Current Selection("Extend")),
	Dialog(Edit(Equal(Source Column(:age))), Keep dialog open(1))
Selection when not using Row Selection:
Wait(2);
ageVar = 15;
dt << Select where(:age == ageVar, current selection("extend"));
If there is no need for dialog, I would most likely always just use << Select Where (without Row Selection) as the syntax is easier and I'm not sure if Row Selection brings anything extra to the table besides the dialog.
Not sure who to tag here from JMP/SAS to take a look into this.
