Wantj43
Column properties add-in
One of the jmp tutorials referenced an add-in for copying column properties. Can someone please give the name and location of the add-in?
Thank you
Thierry_S
Re: Column properties add-in
I assume that you are using a version of JMP older than 15 because the Copy Property function was added to the Column context menu (right-click on the column header) around the release of that version.
I remember using am Add-In a few years back, but I could not find it in the JMP Add-In archives.
Let us know which version of JMP you are using.
Best,
TS
Thierry R. Sornasse
Wantj43
Thank you
I am using jmp 16. When I right-click on the column header the option to "Paste Column Properties" is displayed but not "Copy Column Properties". Am I missing something?
Thank you
Joe
It could be that there are no "special" column properties to copy and that's why the menu isn't showing.
Depending on what you are trying to do, Standardize  Attributes might also be helpful.
