jeric
Column formula referencing variable column names
Greetings,
For analyzing electrical data I want to create new columns with an absolute value formula referring to other columns whose names may be different in different data sets but start with "ID" or "IG".   When I apply below the formula for every new column is the absolute value using the last measurement column found, not the column corresponding to different measurement columns.  How should I express that each "ABS" formula applies to the measurement column?
cdt = Current Data Table();
ColNames = {};
ColNames=cdt<< Get Column Names(string);
for (i=1, i<= N items(ColNames), i++,
if (Substr(ColNames ,1,2) == "ID" |
     Substr(ColNames ,1,2)== "IG" ,
      col = Column(i);
      New Column("ABS " || ColNames , (Formula(Abs(As Column (col)))), format("Scientific", 6, 1));
ian_jmp
Level X
Re: Column formula referencing variable column names
NamesDefaultToHere(1);
// Make a table . . .
dt = NewTable("ETEST",
  NewColumn("ID_1", Numeric, Continuous, Formula(RandomNormal())),
  NewColumn("ID_2", Numeric, Continuous, Formula(RandomNormal())),
  NewColumn("Not Required", Numeric, Continuous, Formula(RandomNormal())),
  NewColumn("IG_1", Numeric, Continuous, Formula(RandomNormal())),
  NewColumn("IG_2", Numeric, Continuous, Formula(RandomNormal())),
  AddRows(10)
// Add new formula columns as required . . .
cols = dt << GetColumnNames("String");
Wait(3);
For(c=1, c<=NItems(cols), c++,
  If(StartsWith(cols[c], "ID") | StartsWith(cols[c], "IG"),
  // Template expression for adding the new column by a formula
  CMD = Expr( dt << NewColumn("ABS("||cols[c]||")", Numeric, Continuous, Formula(Abs(colTBD))) );
  // Update the expression with values for this iteration . . .
  SubstituteInto(CMD, Expr(colTBD), AsName(cols[c]));
  // Add the required column
  CMD;
ian_jmp
Level X
  AddRows(10)
Wait(3);
  CMD;
jeric
Works like a charm.  Thank you, sir!
