Column Character Matching Formulae
Hi All,
I have a dataset with 2 Columns, I just wanted to check to see if the data in Column 1 is matching with Column 2, It doesn't have to match row by row. All what i am interested in checking is to see if we have the same observations, The order in which they are in both the columns if not a concern.
Can anybody help me with a formulae to be used to check this?
Thank
Shawn
Re: Column Character Matching Formulae
Here is an example of one way to do this
dt = New Table( "Example",
	add rows( 100 ),
	New Column( "c1", set each value( Random Integer( 1, 1000 ) ) ),
	New Column( "c2", set each value( Random Integer( 1, 1000 ) ) )
dt << New Column( "Is in Both",
	formula(
		As Constant( c1Matrix = :c1 << get values );
		If( Length( Loc( c1Matrix, :c2 ) ) > 0,
			1,
			0
You can also use associative array to compare the results IF you don't have decimals in your Column 1 and Column 2
dt = New Table("Untitled",
	Add Rows(3),
	Compress File When Saved(1),
	New Column("Column 1", Character, "Nominal", Set Values({"A", "B", "C"})),
	New Column("Column 2", Character, "Nominal", Set Values({"AA", "B", "C"}))
dt << New Column("Diff", Numeric, Nominal, Formula(
	As Constant(
		aa1 = Associative Array(:Column 1);
		aa2 = Associative Array(:Column 2);
		aa1 << Remove(aa2);
		N Items(aa1) > 0;
