Steffen_Bugge
Color cells by conditional formatting
I need a script that looks through all columns and color cells with the value "< LOD". My script does not give the desired outcome. Any advice?
dt = Current Data Table();
// Get all of the column names in the data table
ColNames = dt << get column names( string );
NRows = N Rows( dt );
// Loop through each column and row to find "< LOD" and color the previous cell
For( i = 1, i <= N Items( ColNames ), i++,
	column = Column( dt, ColNames[i] );
	For( j = 2, j <= NRows, j++, // Start at row 2 to avoid coloring out-of-bound cells
		If( Row(j) == "< LOD",
			column << Color Cells( j - 1, "Red" );
Re: Color cells by conditional formatting
This looks for value "F" but most likely gives some ideas what you could change (get all rows beforehand for each column, color cells argument ordering, ...)
colnames = dt << get column names(character, string);
For Each({colname}, colnames,
	r = Loc(dt[0, colname], "F");
	If(N Items(r) > 0,
		Column(dt, colname) << Color Cells("Red", r);
Write();
Edit: Removed unnecessary Show(r); from the loop
Steffen_Bugge
Other and more elegant solutions are more than welcome!
	If(N Items(r) > 0,
Write();
