Cochrane-Mantel-Haenszel analysis
mawriter
I have to confess to being stymied by the Help function in JMP 9 - it give me a list of results but then no further information when I click on the list
How in the world do I conduct the analysis mentioned above... I assume it can be done based on the results when I put the term into Help, but I can't find further guidance.
Any help appreciated!
David_Burnham
Analyze>Fit Y by X.  Specify categorical variables for X and Y and it will take you into the Contingency Analysis platform.  The CMH test is located on the red-triangle hot spot.
Dave
-Dave
David_Burnham
Dave
-Dave
mawriter
Thank you Dave,
I figured it out after I posted the questions. But now I'm thinking that Cochrane-Mantel-Haenszel analysis is not what I need.
