Herrera5238
Close data table before stop() gives I/O problem
I'm receiving this error
I/O problem.
Unable to open in ReadWrite mode.
The system cannot find the file specified.
Test.jmp
When I run a script like this.
dt = Open Database(
		connection,
		query,
		"Test"
	list = :aColumn << Get Stored Values;
selection = Expr(
window = New Window ("Selection",
	<<Modal,
	PanelBox("Selection",
		rbox = RadioBox( list, value = rbox << Get Selected;),
		value = rbox << set(1);
If( window == {Button( -1 ) },
	 Close(dt);
	 Stop();
selection;
I'm not to sure what I'm doing wrong?
Thank You
Daniel
Herrera5238
Re: Close data table before stop() gives I/O problem
I just wanted to share that I found that if I add No Save to the close statement I do not get an I/O error.
So once I changed my close statement from
Close(dt);
to
Close(dt, No Save);
 I had no error.
Not sure as to why but this resolved the issue I was experiencing on this post but it did.
Herrera5238
Close(dt);
to
Close(dt, No Save);
 I had no error.
