Classification of Variables
Hello I am very new to JMP but I would like to check about for validation of chromatographic methods what the correct categorization of the variables should be:
For instance UV detector wavelength (would this be discrete numeric?)
Column Temperature (continuous)
Flow Rate (continuous)
Mobile Phase A Buffer concentration (continuous)
pH of Mobile Phase A (continuous)
Many Thanks
James
statman
Re: Classification of Variables
Categorization for what?  Are you planning on running an experiment?  The categorization will depend on how the data is collected.  My initial guess is your categorizations are OK.
For DOE, you can start here:
https://www.jmp.com/support/help/en/16.2/?os=mac&source=application#page/jmp/design-role.shtml#
