Luq2
Changing value label in the entire data set
i have the following problem at hand:
My variables have value labels in English and I need to replace them with a language overlay of another language. I have English and other languages in a structured format.
is there any way to export the value labels and import the new ones? With variable names, I just copy paste, which works fine.
With value labels I haven't found a solution yet.
Thanks
Sebastian
Re: Changing value label in the entire data set
Here is the syntax required to change the value labels for a column
names default to here(1);
dt=open("$SAMPLE_DATA/Big Class.jmp");
// English
EnglishList = {"F" = "Female", "M" = "Male"};
dt:sex<<set property(value labels( EnglishList ) );
// German
GermanList = {"F" = "Weiblich", "M" = "Männlich"};
dt:sex<<set property(value labels( GermanList ) );
