Cell value in new column
Hi All,
I would like to get a value e.g. for I=20, from I column and put this value in a new column with a new name. I would be grateful for your help and advice. I am new to JMP and learning.
Re: Cell value in new column
Doing this task interactively, you can:
  1. Click on the Cols pull down menu and select "New Column"
  2. Click on the 20th cell in the I column
  3. Right click and select copy
  4. Now click on the first cell in the new column
  5. Right click and select paste
Using JSL
dt = Current Data Table();
dt << New Column( "the new column" );
dt:the new column[1] = dt:i[20];
Using JSL
