SpannerHead
Categorise Columns by initials
I'm trying to list available categories of columns based on the first 3 letters of the column title.  I can list all the available values readily but I have many duplicates.  Summarize doesn't obviously work for anything but a list of columns and what I have is a list of initials.  I tried this with no luck.  Any help appreciated.
dt = Current Data Table();
dt << Clear Column Selection();
colList = dt << get column names( string );
found_list={};
For( i = 1, i >= N Items( collist ), i++,
Spud = Char(Munger( Head Name( As Namespace( colList[i] ) ), 0, 3 ));
	If( !Contains(found_list), Spud, insert into(found_list, Spud ))
Show(found_list);
Slán
SpannerHead
Re: Categorise Columns by initials
Does this get you any further along
names default to here(1);
dt =
// Open Data Table: semiconductor capability.jmp
// → Data Table( "semiconductor capability" )
Open( "$SAMPLE_DATA/semiconductor capability.jmp" );
for each({col,index}, colList,
	colList[index] = substr(col,1,3)
grps = associative array(colList)<<get keys;
It returns all of the unique 3 letter names
dt =
SpannerHead
Thanks Jim.  There's a ; missing but works well.
Slán
SpannerHead
