robot
Capture Error Message Text
I am using JMP12 to pull data from ODBC.  Most of the time this works great, but sometimes an error is thrown and JMP will return an error message to the log.  Is there a way to capture the error text to display in a message box or something?
An example error message is below:
"[Microsoft][ODBC SQL Server Driver][SQL Server]The query processor ran out of internal resources and could not produce a query plan. This is a rare event and only expected for extremely complex queries or queries that reference a very large number of tables or partitions. Please simplify the query. If you believe you have received this message in error, contact Customer Support Services for more information."
Thanks!
vince_faller
Re: Capture Error Message Text
If you run your database call inside of a Log Capture, you won't have to run through the entire log list.
logtxt = LogCapture(
     databaseCall()
Vince Faller - Predictum
mpl34
If you know you are looking for an ODBC error like this you can search the log by using the getlog() function in your script, e.g.:
log=getlog();
for(i=1,i<=nitems(log),i++,
if(contains(log[i],"[Microsoft]")>0,
newwindow("Error",
<<modal,
vlistbox(align("center"),
textbox(log[i]),
buttonbox("OK")))
robot
Thanks!
vince_faller
     databaseCall()
