PhamBao
Cannot set value from list a variable
Dear all,
I try to do scripting, but find difficulty and need your help
para ={"align_ratio_2","align_ratio_1","minchaseforcef_3","maxchaseholdforce_4"};
1) U1L1_MEAN[1] = Col MEAN(TCB1L_U1:para[1]);
2) U1L1_MEAN[1] = Col MEAN(TCB1L_U1:align_ratio_2);
There are different outputs between 1 and 2. For further checking, the output from 2 is correct.
Can anyone help me how to correct statement 1
Sincerely,
Re: Cannot set value from list a variable
Here is the way I would handle your issue.  I am using the Big Class data table for my example.
// Open Data Table: big class.jmp
// → Data Table( "big class" )
dt << New Column( "U1L1_MEAN" );
para = {"height", "weight"};
:U1L1_Mean[1] = Col Mean( As Column( dt, para[1] ) );
