USNA71
Can we get a hold of the sample data files for Teaching Elementary Statistics with JMP?
I have the 2011 book, but the data files are no longer in the Sample Data set with JMP 17.
peng_liu
Re: Can we get a hold of the sample data files for Teaching Elementary Statistics with JMP?
I looked at the first couple chapters on OReilly. I am not sure the data sets in the book are part of JMP Sample Data. For example, Gazelle in Chapter 1 and TensileStrength in Chapter 2. I have never seen them in Sample Data. The author did not mention the data come with JMP Sample Data. Based on my experience with reviewing JMP related books (other than JMP Documentation) published by SAS, I have not seen books use JMP Sample Data as examples. The book points to the following link
But the link no longer works. I suspect that your best chance is to contact SAS Support https://support.sas.com/en/support-home.html
fja
fja
Hello!
No, I haven't found that in JMP 17s sample files either. Would it be an option to contact the author directly?
I guess it was this guy: https://www.grinnell.edu/user/olsenc
I do not know if this is his current position. The CV published there is from '13.
--fja
peng_liu
That is worth trying. LinkedIn, SAS Publishing might be something else.
fja
fja
Yes. www.archive.org is our friend. (Do not forget to donate.)
