NathanFisk
Can an IF formula use boolean character filtering?
Hello all,
I'm trying to run a column creation formula in JMP and I can't figure out how to get the system to perform the function I'm wanting.
Specifically, there is a column of Serial Numbers of six characters.  The first character is always an "S" (for serial number).  The next 5 characters will always be a sequence of five numbers that begins either with a 7, a 5, or a 0 (representing three different product generations).
What I'd like to do is make a formula that does an "IF" function that says "IF (VAR) = S7* THEN "3"" ... which would look at the serial number column and see if it started with an S7 then it would set the new column's value to 3 (3rd generation) and so on with generation 2 and generation 1.
Is this possible with the JMP formula logic?  There's a ton of options but its a bit complicated figuring them all out.
Re: Can an IF formula use boolean character filtering?
Many options for this, if-elseif most simple one
If(
	Starts With(:col, "S7"), "3"
	, Starts With(:col, "S3"), "1"
	// and so on
you can also chain the if-statements if necessary or use IsMissing(Regex()) for more complicated pattern comparisons. If you can provide example data we can provide better examples (add wanted result column if possible).
hogi
Level XIII
another option: Match
New Column( "generation",
	Formula( Match( Word( 2, :Column 1, "" ),
"3", 1,
"5", 2,
"7", 3 ) )
NashTaylor
Thank you.
Boolean filtering can be a game-changer in data processing, simplifying conditional logic. Similarly, structured thinking is essential in writing creative essays. Coming up with fresh, engaging topics can be challenging, but GradesFixer https://gradesfixer.com/blog/creative-essay-topics-inspiring-ideas-for-your-next-masterpiece/ provides a collection of unique creative essay ideas to inspire original work. Whether structuring a dataset or an argument in writing, a logical approach leads to clarity and impact.
