  • Due to inclement weather, JMP support response times may be slower than usual during the week of January 26.
    To submit a request for support, please send email to support@jmp.com.
    We appreciate your patience at this time.
  • Register to see how to import and prepare Excel data on Jan. 30 from 2 to 3 p.m. ET.
BayesRabbit7133
Can I set graph builder title based on variable from a H list box?
I have a H list box window that users can input parameters, after that I will do some calculations and provide a graph builder to user
My question is can I set graph builder title also based on the parameters from the H list box?  below is the sample code
dt = current data table();
nw = New Window( "simulator",
	H List Box( Text Box( "   Input sample rate " ), sample rate = Number Edit Box() ),
	H List Box( Text Box( "   Input threshold " ), threshold = Number Edit Box() ),
	Button Box( "OK",
    thesamplerate = sample rate << get;
	thethreshold = threshold << get;
    numthreshold = num(thethreshold);
    numtime = num(thetime);
    //Here are more code I already finished based on above variable
Graph Builder(
	Variables( X( :File Name ), Y( :greater ) ),
	Elements( Bar( X, Y, Legend( 4 ) ) ),
		Dispatch(
			"graph title",
			TextEditBox,
			{Set Text( "Sample rate =    Threshold = " )} //I want to have sample rate & threshold shown on title
Re: Can I set graph builder title based on variable from a H list box?
You could build the title using Eval Insert or string concatenation.
Here is one option
nw = New Window("simulator",
	H List Box(Text Box("   Input sample rate "), sample rate = Number Edit Box()),
	H List Box(Text Box("   Input threshold "), threshold = Number Edit Box()),
	Button Box("OK",
		//numthreshold = Num(thethreshold);
		//numtime = Num(thetime);
		gb = dt << Graph Builder(
			Variables(X(:age), Y(:weight)),
			Elements(Bar(X, Y, Legend(4)))
		Report(gb)[TextEditBox(1)] << Set Text(Eval Insert("Sample rate = ^thesamplerate^   Threshold = ^thethreshold^"));
You should be able to also insert it directly to the title in SendToReport. Here I also build title variable separately but it isn't necessary but can make debugging and such easier
	Button Box("OK",
		graph_title = Eval Insert("Sample rate = ^thesamplerate^   Threshold = ^thethreshold^");
			Elements(Bar(X, Y, Legend(4))),
				Dispatch(
					"graph title",
					TextEditBox,
					{Set Text(graph_title)} //I want to have sample rate & threshold shown on title
Here is the method that I normally use:
dt = Current Data Table();
	Button Box( "OK",
		numthreshold = Num( thethreshold );
		numtime = Num( thetime );
		gb = Graph Builder( Variables( X( :File Name ), Y( :greater ) ), Elements( Bar( X, Y, Legend( 4 ) ) ) );
		// Set the title
		Report( gb )[Outline Box( 1 ), Text Edit Box( 1 )] << set text( "Sample Rate=" || Char( thesamplerate ) );
Here is one option
	Button Box("OK",
	Button Box("OK",
				Dispatch(
					"graph title",
					TextEditBox,
BayesRabbit7133
Thank you both for your prompt reply
