rleeper
Can I close the jmp program from a script?
I have a windows scheduled task to run a jmp script once a day from our production server.  The problem is jmp stays open after the script is run and has to be forced closed by the scheduler an hour later.  The script takes less than 1 minute to run and leaves no open tables when it is finished.  Is there anyway to close the jmp home screen from within a jmp script?
Jeff_Perkinson
Re: Can I close the jmp program from a script?
Hi rleeper,
You can use the JSL function Quit() to exit JMP.
BTW: You should confirm that your license for JMP permits you to use JMP on a server.
-Jeff
-Jeff
Jeff_Perkinson
Hi rleeper,
-Jeff
-Jeff
admin1
New Member
Thanks for the answer.
My IT department is very strict, we have a license for WinRAR (first place I worked that actually did) so yea we have a server license.
