TamedZebra
Calculating Mode for String Data with Grouping
I attempted to calculate the mode of column A, grouped by column B, using the Col Mode(:A,:B) function. However, since column A contains string data, no value was output. I then discovered that Mode(:A) can obtain the mode even for string data. The problem now is that I don't know how to perform the grouping. How should I construct the formula?
Re: Calculating Mode for String Data with Grouping
You can create wish list item here. You could for example create workflow or script to take care of that extra step.
It is most likely also possible with a formula, no idea how efficient this would be. This should get the mode of :sex over :age
As Constant(
	score_indices = Associative Array(:sex) << get keys
score_indices[Col Mode(Col Score(:sex), :age)]
TamedZebra
// データテーブルを取得
dt = Current Data Table();
process_nm = "A";
// B列のユニークな値を取得(グループ化のため)
unique_groups = dt:B << Get values;
// 新しい列 "mother" を作成
dt << New Column("mother", Character, "Nominal");
// 各グループごとに処理を実行
For(i = 1, i <= N Items(unique_groups), i++,
    // 現在のグループをフィルタリング
    current_group = unique_groups[i];
    subset_rows = dt << Get Rows Where(:B == current_group);
    // A列のキーを取得
    score_indices = Associative Array(Set Unique(Column(process_nm)[subset_rows])) << get keys;
    // グループ内の "mother" 列を更新
    dt:mother[subset_rows] = Mode(Column(process_nm)[subset_rows]);
・Col Mode()は文字列には対応していない
・Mode()は文字列に対応している
・Mode()はグルーピングに対応していない
【対策】
1.文字列を数値のように扱い、Col Mode()を使用する。
2.予め行を絞り込み、Mode()を使用する。
11 REPLIES 11
Do you need a formula or just the result?
TamedZebra
Thank you for your replying, jthi.
I need a formula. I would like to write it on a data table.
Easiest would be most likely to create new column in which you convert your values numeric (Recode -> Labels to Codes can do it) and use that for the calculation. You can then use Copy Column Properties to move over the Label Values column property.
Also, make a wish list item Col Mode() to support character columns
TamedZebra
So, it means it takes an extra step. I understand. I would like to request that Col Mode() supports string columns. Thank you very much.
As Constant(
TamedZebra
I will post a wish list there, thank you.
How did you create the column "S"? I am interested in the idea!
I did provide the formula for S (requires JMP19).
TamedZebra
// データテーブルを取得
unique_groups = As List(dt:B<< Get As Matrix);
// 各グループごとに処理を実行
    // 現在のグループをフィルタリング
    Show(current_group);
    subset_rows = As List(dt << Get Rows Where(:B == current_group));
    Show(subset_rows);
    Show(Type(subset_rows));
    // A列のキーを取得
    score_indices = dt:A[subset_rows] << Get As List;
    Show(score_indices);
    dt:mother[subset_rows] = If(
        Is Missing(score_indices[Col Mode(Col Score(dt:A[subset_rows]))]),
        score_indices[2],
B列のユニークな値を取得し、これを用いてグループごとに処理を行っています。
しかし、これではエラーが出力されます。「You need to input a scriptable object for Send.」。
何か知見があれば教えていただきたいです。
TamedZebra
// データテーブルを取得
// 各グループごとに処理を実行
    // 現在のグループをフィルタリング
    Show(subset_rows);
    // A列のキーを取得
    score_indices = Associative Array(Set Unique(dt:A[subset_rows]));    Show(score_indices);
        score_indices[2],
これでA列のキーを取得するところまでは解決することができました。
jthiさん、お騒がせしました。
