Lavik17
Calculate time difference and summing the values
I have a table with a time column with this format: m/d/y h:m:s
I would like to create a new column called CumTimeSec that will show the cumulative time difference up to that row.
For example,
Time
TimeCumTimeSec
5/11/2022 5:30:03 PM
0
5/11/2022 5:30:08 PM
5
5/11/2022 5:30:20 PM17
5/11/2022 5:30:23 PM 20
I figured I could use this code to calculate the difference between each row, but I'm not sure how to sum the values
dt << New Column( "CumTimeSec",
	Numeric,
	"Continuous",
	formula(  :Time - Lag( :Time) )
Jasean
Re: Calculate time difference and summing the values
Hi Lavik17,
Lag is useful for this application, but you need to use it a couple of times.  Note that Dif() takes the difference between the current row and a "lag" row.  For example, above you calculate :Time - Lag(:Time).  That is the same as Dif(:Time).
Here is an example you can run with JMP sample data.  The table just lists a sequence of years, but it will work the same for a time column.
dt = Open("$SAMPLE_DATA/Time Series/SeriesQ.jmp");
dt << New Column("CumTimeYear", Formula(
	If( Row() > 1,
		Lag( :CumTimeYear ) + Dif( :Year )
	, // else first row
		0
Jasean
Hi Lavik17,
	If( Row() > 1,
	, // else first row
		0
Haven't used Dif before but you could combine it Col Cumulative Sum
Col Cumulative Sum(Dif(:Time))
Lavik17
Thanks @Jasean !! Worked like a charm!!
