jmper
CDF function in JSL
Is there a cdf function in JSL that can return the percentile of a value x with a distribution defined by an array or a column in data table?
I only found functions that return the percentiles for special distribution functions (normal, beta, gamma...), but I need t find out in an array of measured data what is the percentile of one measured value.
ms
Super User (Alumni) ms
Re: CDF function in JSL
There is a function CDF() that generates a list with two matrices that can be used for finding the approximate percentiles. The distribution platform can also be used (interactively or via JSL).
The results will differ between the three methods below, especially for extreme percentiles and small number of data:
Y = :Weight << get values;
{Quant, CumProb} = CDF( Y );
P = [0.1, 0.5, 0.9]; // Example of percentile levels
// Find approximate values of the P percentiles by "matching"
P1 = Quant[Loc Sorted( CumProb, P )];
// Find approximate P percentiles by interpolating the CDF
// For small data sets the results depends much on the choice of smoothing term lambda (here 1)
P2 = Spline Eval( P, Spline Coef( CumProb, Quant, 1 ) );
// Find approximate percentiles using Distribution platform
dist = dt << Distribution(
  Continuous Distribution(
  Column( :weight ),
  Fit Distribution( Smooth Curve( Quantiles( P[1], P[3], P[2] ) ) )
P3 =Report( dist )[Number Col Box("Quantile")]<<get as matrix;
Show( P1, P2, P3 );
ms
  Column( :weight ),
Show( P1, P2, P3 );
jmper
My question was how to get CumProb from Quant and your examples are how to get Quant from CumProb, but the sample principle applies. Thanks a lot!
